I have never seen bushings on a lower control arm. If your talking about the compression arm then those have bushings that are pretty hard to replace and mostly result in damage. I have both side compression arms and a lower control arm for the right side if you are interested.GRed wrote:Can the bushing be replaced or does the whole arm need to
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
