lower control arm install
1990nismo!
Car: 1990 Nissan 240sx
i just bought lower control arms off of ebay they look good but i have no idea how to install them can anyone help
Crazyirish
Car: Nothing noteworthy at the moment...
Front or Rear?
Are they oem control arms or are they adjustable units with solid joints?
Heres a writeup for adjustable front lower control arms:http://www.nicoclub.com/archiv....html
Heres a writeup for replacing the rear lower ball joints. It should give you some ideas for the rear lower control arms.http://www.nicoclub.com/archiv....html
Just make sure you follow proper safety precautions when jacking up the car and working on it. Best of luck!
1990nismo!
thank u!! im installin them rite now and the rears are bein a pain in the a**...... the link didnt show me how to put in after markets.... they dont line up correctly where they bolt to the chasis or w/e
240ingthe240er
Car: Coupe
1990nismo! wrote:.... they dont line up correctly where they bolt to the chasis or w/e
1990nismo! wrote:i just bought lower control arms off of ebay
Philipio
Car: 96 240sx, 96 Miata
Hahaha, my thoughts exactly. I'm willing to bet they don't fit because you bought cheap ebay parts. You might need to adjust something though. Pictures could help if you still need us.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Buy better heim joints
1990nismo!
1990nismo!
-_- i forgot how to post pictures here can someone remind me
Crazyirish
1990nismo!
[IMG][/IMG]
FIRST PIC shows whats not seating properly... the little silver pieces dnt fit into the bracket unless i take one off example next pic
[IMG][/IMG]
SEC PIC dis is it installed without one of the silver things... i dnt think i should drive around like this but idk.. any opinions? also i wanted to kno if the sway bar link part was supposed to b facing up or down............ cuz it seems like i can install the left arm on the right side and the right arm on the left side
Crazyirish
IIRC the s14 rear lower control arm is a little different in dimension from the s13. If you have the wrong one it could cause fitment issues. Or if your subframe is a little tweaked. Also no name ebay arms arent known for their quality fitment.
TheBlaiant
Car: Slow40sx
Those welds don't look to good.
duffman1278
Those welds look terrible.
crakin
Car: 1996 240sx s14, 2008 Chevrolet silverado crew cab,
2011 Suzuki gsxr 750
welds look bad..don't ride too rough keep the Tokyo drifting to a minimum or things might esplode. other than that if the silver bushing cylinders are too big then grind them down to fit or cut them some how. If they are not tight after that then you may want to add washers as spacers until the bushing is tight against the factory frame mount. gl
1990nismo!
thanks for da input people........ last time i buy shyt off ebay -_- crakin das exactly wat im doin now thanks
duffman1278
1990nismo! wrote:thanks for da input people........ last time i buy shyt off ebay -_- crakin das exactly wat im doin now thanks
You can't be serious? Write proper english, or pay more attention in english class.
StandardProspect
Car: '93 Nissan 240SX
'98 Infiniti Q45
Wow
why did you buy these anyway, it looks like your only aftermarket suspension piece, they don't look good either, and don't try Jimmy rigging it with washers. Get a refund and press some new sentra ball joints in your stock arms.
1990nismo!
yo shut da f*** up kid......... is this realli y u come onto nico to check peoples grammer???? its people like u dat keep me away from dis site
Chris28
Car: 92 s13 KA-T
1990nismo! wrote:yo shut da f*** up kid......... is this realli y u come onto nico to check peoples grammer???? its people like u dat keep me away from dis site
And it's people like you that impede the transfer of otherwise viable information.
Thank you for the thread, I was actually wondering what the quality of these arms were.
For the suspension geometry minded out there, what is the benefit of adjusting where the ball joint sits? Roll center? This piece seems slightly adjustable, but maybe it's just how the piece is designed. Other than the heim joint replacing the ball joint, I fail to see how these offer any upgrade to the stock pieces.
Razi
Car: Moo
Yeah, It's the adjustment in roll center.Only helpful to cars that are slammed, useless for otherwise stock cars.I heard most of the heim joints used in these things are junk though.
One thing you can do though, is to buy some PBM aluminum bushings, those raise your subframe as high as possible, about half an inch.That should keep you guys from snapping axles with those crazy drifts you guys do.
Chris28
Car: 92 s13 KA-T
I see, thanks for the explanation!
Maybe next round of upgrades I'll get some subframe risers. I have the slip-in ones now, but only because they came on the car. I jacked my car up by my diff this past weekend and placed a jackstand under the frame rail. when I let the jack down I saw my subframe move about 1/2" before it settled. It's about time for some sort of fix back there haha.
Razi
Car: Moo
Fo sho!
I really want to get solid aluminum bushings but increase in noises is a bit turn off for me.
crakin
some people are griping like he's spending your money. But good luck man and make sure that that C.A. has no play and hope it.s a sturdy part. Be careful dont trust the beauty of a 240 to a cheap part man and have fun modding.
duffman1278
It's not our money, however we're trying to help him out from spending more money. But mr G muney dawg is getting all tip drilled up and anal about it.
1990nismo!
f*** u duechman! i asked about my control arms not about my grammer ......
TheBlaiant
Car: Slow40sx
Gezz just chill out.
I don't like those welds so I wouldn't put those on my car.
