Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed Jan 19, 2005 2:16 am
Metal hat has a glued in rubber isolator with metal center inserts, I recently had to replace both of mine.
Just like the passenger front brakes wear/warp faster the passenger side suspension get subjected to much more road abuse thus faster failures.
The Q design [twisted angle upper link] to simulate the actions of an upper A type wishbone member is under extra wear stress........why they last 30-40k as opposed to 100k [LS400] but the part is cheap and easy to change.
The Lexus design/part last 3 times longer but costs $900 to change.
The Q front suspension is much cheaper to keep right for 250,000 miles assuming you buy the parts at a discount and have a discount tech [yourself] change them.
Interestingly, the LS400 eats multiple rear suspension bushings whereas the Q has very good life......especially passenger rear.
