Lower control arm angle pics! WHOO!!!
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Post pics of your lower control arms angle! how low can you go baby! (i would post a pic of mine but im a lazybitch)
lol
Basically im afraid to lower my car to the point of the arms being under square ie like this haha im afraid of the handling being lost because i love this look so much but if i have to sacrifice handling performance then i may decide against it...
S13Joe
Car: 92 Coupe
that car is beautiful, besides the spoiler.
2projects2many
Car: '91 S13 SR20DET
You answered your own question!
Justin35ll
Car: s13 coupe sr20det
Yeah, you could loose some handling people say, but when my car was that low (not my s13) I thought it handled better lol.Gonna put some extra strain on your cv joints though so you might rip the boots eventually depends how serious the angles are.
spooled240
Car: kouki s14
don't they sell LCA's for slammed cars?
Dittoz7
Car: 1997 2f0WtY SE!
Car Handles Like Beast!
Past Sunday... 12/28/08
ViolentRunning13
Mine is quite lower then that and it handles fine.
spooled240
Car: kouki s14
Dittoz7 wrote:Car Handles Like Beast!
I think drift cars usually handle like **** cuz the car just wants to slide all day via stiff *** springs. A car setup for grip is way different than a car setup for drift.
A slammed car will still most likely handle pretty damn good but it could be better if it was fine-tuned to the best ride height and stiffness. You want a little bit of weight transfer and some dampening so body bouncing doesn't occur and you start breaking ****.
OM3GA
Sexy *** pic man looks awesome.
Justin35ll wrote:Yeah, you could loose some handling people say, but when my car was that low (not my s13) I thought it handled better lol.Gonna put some extra strain on your cv joints though so you might rip the boots eventually depends how serious the angles are.
Yeah i understand that i plan on running silicone CV boots most likely, i dont want to have to replace them monthly lol.
spooled240 wrote:don't they sell LCA's for slammed cars?
I believe megan just started making some and Battle version makes some as well im going to look into them a little more to see exactly what they do.
DirtyGhettoKids wrote:that car is beautiful, besides the spoiler.
Everyones got their own opinion that car looks pretty "perfect" IMO i dont mind the spoiler too much it adds to its aggression.
Razi
Car: Moo
http://www.splparts.com/main4/index.htmGet SPL tie rod ends.They are adjustable, since you can fit a lot of rubber washers on em to bring the tie rod down a bit so it's flatter than it is now.
OM3GA
I actually have Circuit sports tie rods inners and ends but not installed yet. I also have that aluminum steering bushing with the 4 holes that goes on the steering linkage where it meets the firewall.. I plan on installing them both at the same time hopefully the CS tie rod setup will suffice.
nissanman04
Car: '90 240SX, '95 Subaru Legacy
spooled240 wrote:I think drift cars usually handle like **** cuz the car just wants to slide all day via stiff *** springs. A car setup for grip is way different than a car setup for drift.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
It is true that when you lower your car to where the LCA's are "undersquare" it does dramatically change bump steer, cornering, weight transfer ect.
That's why they invented roll center adjusters. It goes in place of your ball joint and re-aligns the roll center for your suspension geometery back to where it should be.
EXAMPLE:
http://www.festivegarage.com/r....html
BrianHarte
Car: 180sx
You own that car?
You are thinking of Megan lower control arms? Are you kidding?
Aftermarket lower control arms that are worth a damn - Ikeya Formula. NAMS.
Gabes13
Car: rb20det s13
Are LCA really that important?I mean, they just hold the knuckle. Aren't tie rods and tensions the determinants of handling?
ddgsxr504
BrianHarte wrote:You own that car?
Are you talking to me? (Robert Deniro voice)
BrianHarte
Car: 180sx
No, sorry.
Was talking to the original poster.Pretty sure that car is a Florida car and the user says California.Just wondering.
Lower Control Arms are pretty important. They are pretty much the "base" of your suspension on the car.
fast_s13
lca's dont make much of a differnts you want to keep your tierods as level as possible.to control bump steer
94_240sx
Car: 94_240SX
fast_s13 wrote:lca's dont make much of a differnts you want to keep your tierods as level as possible.to control bump steer
That's what I'm thinking too. OP should be more concerned about bump steer than LCA.
ArticDragon192
Car: 91 Z32 2+2
Ok, enough of this. LCA's make a big difference in the way your car handles. If your arms are pointing up, your car is not performing at it's optimal level. Roll centers are screwed and in some cases, the wheel will camber out instead of cambering in under extreme compression. Ikeya sells arms with roll center adjusters. Also, S15 rear subframes have different pick up points so that the suspension behaves in a better manner.
24j0hn
Car: 91' 240sx with some babying to be given
**** if i went that low my **** will get f'd up by rocks... i live in the mountains but 240's handle like a beast!
OM3GA
No i dont own that car its just a reference of what id like to see my car look like lol. Anyways i am not considering megan control arms lol like id use that name at the base of the suspension lol i dont trust their name holding everything together haha. I would go with the Battle version arms way before megan believe me. SPL also makes some but ill look into the ones you speak of as well...
yeah i know about keeping the tie rods as level as possible that is very important im basically just trying to find out if the angles of the LCA's affects the handling in a bad way which makes it not worth lowering past the ________ all the way across point...
24j0hn wrote:**** if i went that low my **** will get f'd up by rocks... i live in the mountains but 240's handle like a beast!
Lol excuse me but what does that have to do with anything? lol
