Factory compression on my DSM was 7.8:1float_6969 wrote:To rehash a slightly old thread, I just read something that Corky Bell said, that stated that to never lower the compression below 8:1 on a street car.
That same concept about hoses and o-rings already holds true to our current engines. Typical rubber hoses and o-rings will decompose(? for lack of a better word) when in contact with gasoline for a sustained amount of time. Which is why when you buy fuel lines, you ask specifically for fuel hose, which is not only resistant to high pressure, but treated for gasoline as well.iliketocrash wrote:isn't the e85 the higher ethanol conten blended gas? i think they have at least two grades of it. but anyway, you sure your fuel system is alcohol tolerant? because i read a writeup once about someone converting an older car to accept the blended gas and it talked about needing special rubber compounds for the hoses, o-rings and such because normal rubber degrades quickly because of the ethanol. but i digress. good to hear more info on the compression thing. thanks guys =)
I´ve used E85 on most of my cars for years now and no problem yet.One bad thing is aluminum and E85 together but only in places where the fuel is stored a long time, like fuel tank.iliketocrash wrote:i know that fuel components are specially treated for gas but i'm talking about something different. a different rubber compound is needed due to the addition of the ethanol. or so i hear.
No, it does not. The "turbo lag" is the same. The higher compressor does give it a fatter midrange (in boost).iliketocrash wrote:increase turbo lag
Cocky Bell generalizes things. You can twist what is a "street" car, etc. The fact of the matter, you build the motor for what you are looking for. I am not talking about dyno queens.float_6969 wrote:To rehash a slightly old thread, I just read something that Corky Bell said, that stated that to never lower the compression below 8:1 on a street car.
Increasing (or the willing to increase) timing to make power is silly. Get your intercooler set-up, then dyno it, you will see.float_6969 wrote:I actually increased my compression on my car to improve the off boost response and decrease turbo lag. The problem with doing this (and I'm still currently fighting it) is that you aren't able to run as much total timing on pump gas. I'm hoping that with a more effecient intercooler setup and perhapse some water injection, I'll be able to get more timing out of it.
How many high compression turbo CA's have you built? How many have I built?Coldspawn wrote:No, it does not. The "turbo lag" is the same. The higher compressor does give it a fatter midrange (in boost).
Most people see that and think it is lag.
I see you now think you are more educated than the renowned engineer Corky Bell?Coldspawn wrote:Cocky Bell generalizes things. You can twist what is a "street" car, etc. The fact of the matter, you build the motor for what you are looking for. I am not talking about dyno queens.
Please refrain from trying to educate me on tuning principals. Especially if you're not fully aware of the current tune of my motor.Coldspawn wrote:Increasing (or the willing to increase) timing to make power is silly. Get your intercooler set-up, then dyno it, you will see.
I do not see how it is in any importance.float_6969 wrote:How many high compression turbo CA's have you built? How many have I built?
Any data to back that up? I have dynoed the same set up with different compression. I am not saying you are wrong, but I have seen very different.float_6969 wrote:From EXPERIENCE, my car spools up AT LEAST 200-300rpm's quicker than it used to. I'm also making boost as low as 2000-2200 rpm (1-3psi). I'm fully spooled before 3000rpm. This is on an S15 T28.
Nope, read it again. I have talked to him before, he is very smart. Glad to see you are reading Maximum Boost.float_6969 wrote:I see you now think you are more educated than the renowned engineer Corky Bell?
If your set-up is different then what you have posted here, then no, I do not. Do not be soo closed minded. I never said you had to accept everything I say.float_6969 wrote:Please refrain from trying to educate me on tuning principals. Especially if you're not fully aware of the current tune of my motor.
As you stated, you need a few things to help your setup. I think your air temp going into the motor is on the highside, you are running a cold air intake out of the engine bay? What are you ECTs and IATs?float_6969 wrote:I generally consider myself relatively open minded. But I'm well aware that 9 degrees of total timing is low no matter how you look at it, and when running higher octane, I've advanced the timing and felt power gains.
Of course, You will be able to run more timing with a higher octane fuel. All octane rating is, is the resistance of detonation.float_6969 wrote:And lastly, the point that you keep missing is that I have tested more advance on higher octane fuel and had evident power gains.
I'm NOT saying that you have to advance timing to make power.
It matters the motor, porsches run almost no timing.float_6969 wrote:I AM saying that I am severly retarding the timing to prevent detonation. As a general rule, you don't want to run much less than 15 degrees of total timing. This is is due to the fact that under this much total timing, the PCP starts to happen too late in the pistons' stroke to apply the most torque to the crankshaft.
