I have the same problem with my ca too I believe that its because its sucking in colder air and more dense air and Im using a z32 maf and an afc to tune my car.rico05 wrote:I have noticed a trait on my new motor that is odd. When my motor is cold, it will hit boost cut at like 5-7psi. When warm, I can run ~1bar and never hit cut. I have rationialized this all to hell, but just wanted to hear some thoughts on the subject.
he is talking engine temp wise not ambient temp.....Ca_Silvia wrote:But it definatly seems temperature dependant, its never done it before at the track when its hot as hell. Only later at night when its cold.
I meant cold ambient temps, i see how in that one post its a little confusing. Anyways, i went to the track last night and yes my car was cutting out. Its was only above 6500rpm, motor running 190* coolant temps. It happened a few times, like 3 times in 4 hours of drfiting. Im going to seafoam the motor and change out the plugs and see what happens.float_6969 wrote:Holy crap, I totally mis-read your post. I thought you meant cold ambient temps, not cold engine! Sorry dude.
In that case I would suspect a failing engine temp sensor. Maybe it's pulling too much timing or adding too much fuel?
