Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Nov 28, 2011 2:38 pm
Save your money. The vert has good lateral bracing. The rocker panels have vertical reinforcements every few inches. I've had multiple mechanics comment on how stiff the chassis is from nose to rear. If you want to test it for yourself, jack the nose up and open/close the door. Most cars will have the doors catch a bit because of chassis flex. The vert is usually pretty smooth.
Now, from side to side, the chassis does need reinforcement. But that is best handled by a roll bar.
Now if you were racing your vert, I would consider those bars, but you would probably be better off just caging the whole thing anyways.
