First off, I have a 92 nissan hardbody ext cab 4x4. The question is, I have the old ball joint loose and and unbolted.
When I go to move the ball joint up it hits the drive axel not allowing it to be removed. Does the drive axle have tobe
removed. Everything I have read and seen, no one has mentioned having to remove the drive axle.
Is there a trick to getting it out???? I do have the Haynes Repair Manual and nothing mentioned there also.
Any help would be appreciated.
