Ok so is it really complicated to pull axle out of hub & swing axle out of the way to get the new lower balljoint in. What needs to be taken off to pull axle away from hub, the small parts that whole axle in are a looks to be a horseshoe clip and other parts in the hub,,MaximA32 wrote:The only way to remove it is to get the axle out of the way. If it were 2wd, you would not have this issue since the 4wd hubs would not be in the way.
