Lower A/T on 2002 Qx4
jajja88
Car: 2002 Infiniti Qx4
How do i lower the A/T to change the revolution sensor on A/T?
Do i just remove the Rear Engine Mounting membrane while supporting the Transmission and Transfer Case with a jack and then lower the jack or is there anything else i have to do in between?
Thanks
Hawairish
Car: 2004 Nissan Pathfinder SE 4WD
That's pretty much what the FSM describes...if you have 4wd. Seems like it's accessible for 2wd models. You didn't say which you have.
See AT-273 in your FSM: http://www.nicoclub.com/FSM/QX4/2002/AT.pdf
jajja88
Thanks for the reply. I have 4wd
