gtune4 »
https://forums.nicoclub.com/gtune4-u9024.html
Wed Feb 18, 2004 10:24 am
the car had 2 "brian farts" i guess in the past two days. when they occured, they were occompanied by low jumpy idle, about half vaccum, black smoke like a boost leak. checked everything, no leak? today, i cleaned all of my elec connectors from the ecu out and replaced the pcv valve, tightedned my bov a bit (sound better, less choppy), took the metal screw out of the idle air control valve (iacv) and sprayed carb cleaner in it, let it sit, started it up, repeated, cleaned the screw and used a little 100% silicon on the o ring on the screw (adjusts nicely). started it up and ran the cleaner through the motor. reset the idle ect... now i am getting between -17.7and-18.3 during the middle of a warm day. i imagine that it will go to -18.9 at night. the guy at HT said that 18 was ok. 20 was right on.
so what can cause this slightly low vaccum other than tiny hidden leaks i have yet to find?
timing is at 15 deg and idle is at 750 with approx -18.3 vacuum at idle.
why does my car occasionally have a brain fart. it has happened a total of about 10 times. acts funny, then stops acting up. (maybe after cleaning all that **** it wont do it anymore. i think it was a combo of my idler and bov?!?!?)
also, this all seemed to start when i took out the temp sensor for the gauge and put it back in (dont ask why), mabey i didnt bleed the sys enough?
**** it, it works :ylsuper
does it ever end.... not that i mind.... i love my car... i hate my car... i love my car....like my ex girlfriend?:D
