low vac/****ty idle
originalsin
ok so i just got done replace my headgasket, everything is good, except now i have low vacume. i replaced all the lines, so i doubted it was that, but i decided to clamp them off and see if it helped at all, no dice. im pulling like 15in hg. car is idleing at like 1000-1500 but if i let it idle for to long it like cuts out to 500 and seems to be sputtering, but doesnt die. also, last year i was boost 12psi (due to 3in turbo back and intake i think) but this yr only like 9-10 lbs
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Welcome to the club. Mine only pulls 10" of vac at 800 rpms and about 15" of vac at 1200 rpms. I think mine is a timing related issue though.
originalsin
any1?
shane_lxi
Car: '71 Datsun 521, '89 240sx coupe, '90 240sx fb, and 2 s13 shells
mine kind of did that before retiming it, now I get about 19"-20". Also, the idle thing was a seperate issue for me caused by having too large a maf without an AFC.
tyrannix
Car: go big or go home
out of curiosity, have you done a compression test since changing the headgasket?
CJ
originalsin
no but i should, runs rly strong tho
i will dial in timing 2marow tho
dvd
i think i have the same problem as you guys too
c-rad
I got mine fixed. It was the timing that was off.
