Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed Dec 15, 2004 3:31 am
If the ATF passs the color test [white paper towel side by side with a drop of brand new ATF]................. you don't need a Quick Clean.
NEW ATF has enough detergents to clean varnish.............it's when you let the ATF degrade by running it too long or too hot that these additives are overwhemed or become useless by themselves changing chemical make up.
A QC every 2-3 years 30-45k should be enough if you change the bulk of the ATF every year ]or even two] depending on the color test.
When fluids change color or begin to wash out the color.......lighter and lighter less saturated red [in ATF case, or less clear/darker in other lubricants without dyes].............time to change them.
If you change oil every 90 days and others every year you don't have to worry about fluids [diff, atf, ps, brake/abs, coolant] when you stretch their life you have to worry..............7 year coolant HA HA..........life time fills mean short life times........diff might last 3 years depending on enviroment and how soon you want to pay $2500 to replace it.
Same with AC oil and dryers.......compressors and evaps are expensive.
Easier for me to just change all fluids every year then fluids plus gas filter are not on my mind. $400 is just 15% of the total M&R cost. Leaving $2600 for tires, brakes and prorated [60k services] repairs/replacements.
