Finite35 wrote:I've put the air in myself at roughly 50psi, mind you this is one of those crappy gas station guages which are not all that accurate. I did not check the pressure in the other tires which I should have. I added the air in about 3 days ago and the light is still there. I'll check the rest of the tires today and see what happends
Thanks for the help!
Finite35
Welcome to NICO
Never rely on gas station air pressure gauges
Invest in a good quality tire pressure gaude
http://www.amazon.com/Moroso-8...r=1-1
You can find cheaper ones but read the reviews. Usually buying cheap means you are going to buy twice.
35lbs when cold. The tire pressure warning light will go out usually within 200 miles. You can do the math conversion to km
Telcoman
