Low Tire Pressure Warning Light
nyjohn
Does anyone know if the low pressure tire warning light should come on when you first turn the ignition? I've never seen the warning light, even when I first turn the ignition, and someone mentioned to me I should probably be seeing it.
Phil'sFrontier
Car: Nissan Frontier SE kc 4x4
If your light goes off after a few seconds, then it is normal.
philipa_240sx
The TPMS light should briefly appear when the ignition is in the ON position just before starting.
IdaCrue
Car: 2008 Nissan Rogue
I have had the TPM light come on while driving. I was at mile 75 of a 100 mile trip on I-15 when the light started to flash. It flashed for about a minute then went out. I pulled over at the next off ramp and checked the pressure. All four tires were at the proper inflation. I pulled out the owners manual and discovered if there is a malfunction in the TPM system the light will flash for 1 minute then go out. I haven't had the light come on since, but if it does, I will go to the dealer and have them check it out. Has anyone else had this happen to them?
Return to “Rogue Forum”
