Low Tire Pressure Indicator when tires are good
jmbones
My wifes Rogue is displaying the low tire pressure light but all tire pressures are good. Is there a known issue with bad sensors or something else with the TPMS?
jmbones
Ok.. so the light went out after a couple key cycles. One tire was down about 4lbs, is that enough to cause the idiot light?
SquiggyFreud
mine does I keep my tires at about 35 PSI, if one drops below 30 it comes on. After I fill it light goes out within 30 minutes.
philipa_240sx
The TPMS system triggers at 26.5psi. However it can vary depending on altitude and the accuracy of your tire gauge.
Read more in the TPMS FAQ thread in the Official Rogue FAQ.
Return to “Rogue Forum”
