Low temperature indicator light(LTI)
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
HTTP404
Car: Nissan Versa 2009 1.8 SL
Friends told me that I should wait untill LTI turns off before I drive.
I tried once but the LTI was still illuminated after 5 minutes (and I gave up waiting). When I drive with the LTI on, it goes off around 3 or 4 minutes. Is it a normal time? I think it is not good for the engine because I drive uphill very often when engine has not wamed up.
CrankyVersa
Car: 2010 Versa 1.8 hatchback SL
Completely normal. mine does that when its a bit cold outside, but goes ofter 2 or 3 minutes. Just dont reall drive hard until it goes off would be my opinion.
HTTP404
Thank you for your reply
2dr_sentra
Car: 1997 200SX SE-R, 2007 Versa SL 6spd
The Low temp light shuts off at 130* water temp.
Bubs360
Car: '09 Versa SL, '84 Vanagon
Just don't drive it hard until the indicator goes off and you will be all set.
Return to “Versa Technical Discussions”
