Well why you trying to take the intake Mani off? You can get to the Iacv w/o taking off the Mani! Also replace that vacuum line with the hole in it, that is what usually causes symptoms like your describing!Jaesx wrote:went to take the intake manifold off to get to the iac valve and found a big hole in a vac line im pretty sure that could cause the problem right? But i have all of the bolts and stuff off the top of the manifold i just cant get it to come off how the hell do you get this thing over the studs?
