TruenoAE86 »
https://forums.nicoclub.com/truenoae86-u262398.html
Mon Mar 07, 2016 3:23 pm
Hi, guys, have you fix this problem?
Timing chain job its mean you need to remove front cover, and after put everything back , and most problem is to put back oil pump , because if the pump have wrong position , distributer will not work properly , I have same problem , and I hope in few days its will be ok.
