S13ChucKAT »
https://forums.nicoclub.com/s13chuckat-u16876.html
Wed Oct 20, 2004 12:44 am
I figured a way to make the headlights flip open like.. 3" from the bumper, so it makes it very slim appeal... after actually doing it, and gettign a good hard look at it.. I didnt like it..
what i did was take off the black headlight surround plastic guarder thing.
on the inner part of the headlight flip up housing there is a old screw that was used for hte black plastic surround..
i removed the little screw holder that was in there, and there was a big square hole.. i went to home depot, and found a bolt that was smooth headed, with a square in front of it, followed by a bolt.. 3/8 to be exact..
then i used the stock headlight actuator arm, and popped it off the flip up part.. Moved it to that plastic trim location, bolted it in, and then tested it out.. headlight closed to a stock height, and raised 3" off the bumper...
Then you have to make all the custom brakcets for holding lights... other than that, its not hard at all..
GL..- Im going to be making flush mount headlights.. i believe it will be better.
