Low Profile for 2010 G37x Sport Sedan
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
oldpond
Car: Infiniti G37x Sport
Hi folks,
I have a set of MSR rims that came with my G37x. They have General Exclaim UHP 245/35/ZR20 95W 690Kg/1521LB tires on the front and General Exclaim UHP 275/30/R20 97V 730Kg/1609LB tires on the back. The tires came installed on the rims when I bought the car, so in the spring I had Nissan install them. They had quite a bit of trouble with the tire pressure sensors, and in the process (I believe) damaged the inner side wall of the back ones. Long story short, I have a slow leak and need to replace the back tires.
My stock rims have my Michelin X-Ices on them, and I'm not stuck on these rims. I'd like to go with something a little sexier than the stock rims in summer, but still have my tire pressure sensors working. I do a LOT of highway driving (1200 Kms every two weeks). When I first got the car it had a tendency to jump all over the road. I assumed it was the square profile Dunlops that came stock, and given the roads are very seldom flat up here, I went with the more rounded Michelin's for winter driving. The General Exclaims that are on the MSRs are a little more behaved than the Dunlops, but they are a little more energetic than the Michelins. So, suggestions?
Also, I read the alignment thread, and I'm a bit worried my usually trusty Nissan guys may not be as savvy with my G as they should be. I did get them to do an alignment when they installed the MSRs, but I wonder if I should go to Infiniti to get another one once I replace these rear tires.
audtatious
For summer I've been quite happy with the Pilot SuperSports. They do seem to tramline a bit but that may be due to my camber. Otherwise they are phenomenal in the rain and have great dry-weather traction.
oldpond
I've never heard the expression "Tramline" before. Thanks for that. Glad to know there's a word for it. Should I have the techs look at the camber?
audtatious
Your local tire shop is probably better equipped for a proper alignment than Nissan.
If the highway in your area is grooved for rain then you can easily have annoying tramlining. Truckers ruts as well.
oldpond
Lots of trucker ruts on the Transcanada Highway. :) I also notice even a slight grade in the road causes it to drift to once side. That's probably expected given the nature of this car. Thanks for the advice, audtatious!
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
