BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Thu Oct 02, 2008 3:25 pm
Your TPMS should not have to be reset by the dealer. Fill all four tires to 40 PSI with the ignition off (not required, but suggested); the light should go off. Then, adjust tires to proper inflation. That simple!! Yes, these sensors communicate to the vehicle via radio waves, so the metallized tint question isn't a bad one. It's not the answer, though. The sensors are located somewhere near the wheels. **CORRECTION!!!** The TPMS reciever is located near the center/rear of the cowl, and is the same transceiver used for the remote keyless entry!!
If your light is flashing, you likely have a malfunctioning sensor or body control module; that is a dealer visit.
Steady "on" generally means a bonafide low pressure situation.
Welcome to NICO!!
Modified by BBISHOPPCM at 6:42 PM 10/2/2008
