Ever Victorious »
https://forums.nicoclub.com/ever-victorious-u44595.html
Thu May 24, 2007 5:25 pm
looking - The OEM wheel sensors should fit aftermarket rims. Do you know what they did with the original Nissan rims? They probably got cheap and didn't take them off the rim. Even if you have a set of rims that the OEM sensors do NOT fit, there are aftermarket TPMS sensors compatible with the original BCM.
Go back to the dealer, demand (politely) that they fit sensors (original or aftermarket) since they are required for the TPMS system, which is 1) one of the features listed on the window sticker (it's fraud if they disable it and didn't tell you before you drove off the lot) and 2) they should have done this to begin with.
Cruncher - take it back to your dealer. Tell them that the BCM has failed. It's a well-known issue with these. If you need support, use the search function and search for "TPMS"... make sure you select the "post bodies" option, so all of the threads show up, not just ones with it in the title.
