low pressure power steering line in sohc
aurora61
Car: 1990 240sx hatch
when swapping a sr20det in a sohc 240, wat needs to change is the high pressure and low pressure power steering lines rite?
the high pressure ps line seems fairly straight foward. it seems to go straight from the rack to the pump... i read that these can be built urself by getting the proper fittings and a long enough power steering line.
wat about the low pressure line? it doesnt seem as straight foward as the high pressure line...
so is there a way to make one urself? (all the diy power steering line info seems to only be about the high pressure line)
also, do you have to get one off the dohc or is there a way to manipulate the sohc line to work?
