low power steering fluid whine
e_c
Car: 1990 240sx
when i first start my car and hold the brake i get the low power steering fluid whine, but all of my fluids are at the right level... its only for a few minutes then it goes away, but comes back randomly only when i hold the brake....BTW i have a 1990 with ka24ethanks for any replies
Fenvy
Car: 2005 350Z Base 6MT
hey never heard of this problem but maybe you try start by flushing brake and ps system... maybe that'll remedy your problem?
e_c
Car: 1990 240sx
how would i go about doing a flush of these systems?
Fenvy
something like this can be better explained if you do a search
basically from what I remember from MY search, the power steering system is hard to flush so you actually want to use a pump to pump out old fluid from the resevior, drive for a few day, pump some more... repeat a few times. Personalyl I went with vasoline's ATF to do the job since it's synthetic and it's red (you can see the progressional change every time when you pump it)
as for the brake fluid, it's probbaly a 2 person job, that's the only way I know how. Basically need to have a thin hose between a bottle of brake fluid and the brake fluid resevior. Set the bottle to be much higher so it'll siphon to the resevior.
1 person pump and build up pressure in the brake system, stop, other person release pressure from the brake calipers, stop, repeat
the sequence of calipers are from farest to the closest to the resevior
I am going pretty vague, but this subject has been covered a few times in the past and a search will yield better info or even visual than what I can offer
