adam-gtX wrote:this could be completely wrong but, lash adjustment?
They're hydraulic lifters. There is no adjustment.
kapower06 wrote:It sounds like your pump is taking a **** on you to be honest. And the lifters are ticking because of that issue. I was getting 18-20psi on NOT idle, and around 65-70psi on 3.3krpm or so. And would almost get up to 85-90psi up around 7500rpm. I can send you that oil pump for cheap if you want to try it. Give my $25 for shipping and if it fixes your problem, agree to send me another $50? lemme know, becuase if your lifters are ticking I would be scared the mains and rods are close to knocking on you....
It better not be. It's a brand new oil pump from Nissan. I used to get multiple lifters ticking, but after changing the HG, I've just got one that does it now. I'm wondering if it's just messed up because the pressure has been low, but I don't think it works that way.
I'm going to pull the pan this weekend and see what I see. If the Main and Rod bearing clearences are still in spec, don't show any unusual wear, the screen and pick up are clear, and the pickup gasket seems to be seated OK, I'll pull the pump and take it apart and see if there is something wrong internally. If I can't find anything wrong, then I'll contact you and try your pump.
If I do find something out of what, I'll update this thread.
