tyrodtom »
https://forums.nicoclub.com/tyrodtom-u133407.html
Tue Aug 11, 2009 7:48 am
You would've had to take off the front cover to replace those parts. If either one of the 2 o-rings to and from the oil pump in the front cover is bad, you lose most of your oil pressure, also the same thing happens is the gasket on the oil tensioner fails.I'd check those out first.
