low oil pressure in M45 ?
yidal8
It happened twice already . If I don't drive the car for more then 4-5 days ,there is no oil left up in the valvetrain . When I start the car again after this period , very ugly clacking noise comes from the engine , for about 3-6 seconds , until oil pressure builds up . I don't like it . Never happened in my 91Q , or if it does , it is not this bad .Anybody knows about thid issue with the new V-8
metaverse3
I'm assuming you checked oil level using the dipstick ? What weight do you run in the car ? could be a lazy oil pump or a blocked galley. New car, but not necessarily pefect.. Check the oil viscosity and do an oil change, if possible two to flush out the system..
PalmerWMD
Car: 2004 350Z
metaverse3 wrote:I'm assuming you checked oil level using the dipstick ? What weight do you run in the car ? could be a lazy oil pump or a blocked galley. New car, but not necessarily pefect.. Check the oil viscosity and do an oil change, if possible two to flush out the system..
What he said.
Fred..
qship96
Car: 1996 Infiniti Q45
could be faulty anti-drainback valve,allowing filter to empty on shutdown,therefor no oil flow upon restart until filter refills.
PalmerWMD
Car: 2004 350Z
Good point Qship.Yidal you're not using a Fram or other cheapo filter with no or poor anti-drain back valves?
Of copurse even on good filters they some times become stuck.
Fred..
yidal8
Always change oil @ dealer . I assume 5W30 .Less then 1000 mi. since last change . Oil level is good . I guess nobody else is having this issue ? Should I complain ?
PalmerWMD
Car: 2004 350Z
I woul;d bring it up.dealers generally use 5 w-30 (some use 10w-30 in summer).
Chances are your antidrainback valve in the filter has malfunctioned
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Worse comes to worse itd be a great excuse to get a new engine!
Q45tech
Look at the new design for lower friction valve lifters on the 2002 and later 4.5.
