Low oil pressure 08 Se-R
dboz99q45t
Car: 1999 Q45T
Does anyone know what the oil pressure should be at idle and at about 2000rpm and above?????
djtorello
Car: 2008 nissan Sentra SE-r
dboz99q45t wrote:Does anyone know what the oil pressure should be at idle and at about 2000rpm and above?????
Idle should be about 20. 2000 rpms, maybe 40 at most.
What does your gauge say?
dboz08ser
Car: 2008 Sentra Se-R
Changed the user name because changed rides. Cold is about 70. Then goes to 30 at 1700 rpm. Them between 15 - 20 at idle. Just got the car and just trying to get a baseline. I am panning on changing fluids so I know exactly what is in it. I usually run Royal Purple. What do you recommend?
djtorello
I usually run Eneos at the tracks. All other times Penzoil Platnium.
The Penzoil Platnium is far better then Mobil 1, Syntec, Q'Horsepower, etc...
dboz08ser
Thanks for the advice. Any particular oil filter?
djtorello
Just about anything except fram.
