HxC_Nismo wrote:its sounds like you have no compression check your compression to make sure its good.an engine needs 4 things to startfuel, spark, air, compression so since you have 3 of those check the last one.also an engine can run without oil psi just not for a long time lol
Yeah, I've already checked everything except the compression, but I still fail to see how it would lose compression from the battery going bad.
I pulled the supply line off the fuel filter and got a nice stream of gas with key on...
For spark I cheated a little and stuck my timing light on the test wire and cranked if over, so it is possible that the plugs themselves aren't firing.. I took a shortcut, I know..
I checked all the intake and piping for collapsed, crushed or damaged hoses and found nada. Even check to make sure the TB was good and it wasn't blocked, siezed or maybe something lodged in the butterfly..
I do know one coil at least is cracked, and it almost definitely needs a set of plugs, but I figured it would still start since it was doing so fine before the battery went dead.
What about water in the gas? I would think it would lock up... but it is a low compression motor... Just trying to puzzle this out.. heh... You guys know how it is sometimes.
