Jerky_san wrote:I've noticed that the CVT has a extremely long warm up time.. Mine will finally drop into low gear by the time I'm pulling into my work's parking lot a couple of miles away in 30-40 degree weather. If I "warm" it up the blue light will go off but it will never down shift really.
You'll never get good mileage until it's warmed up, so if you're only driving a few miles at a time, that explains a lot about your lousy mileage. Mine takes about two miles of slow driving for the blue light to go off when it's below freezing, but even then I don't figure the engine's getting good mileage yet. Down shifting? Mine is the same cold or warm, but since I keep it below 2000rpm until it's warmed up, there's really no downshifting to speak of!
Quote »I figure if you had a manual then you'd probably get better mpg just because you could avoid the high revs of warm up time.[/quote]I was ready to get a manual but went with the CVT because it was rated to get better mileage. Since mine's mostly highway it makes more of a difference, though, because the manual runs at much higher rpm's on the highway.
Quote »Anyways your going to be cursed with poor mpg so you best just get used to it by what I've found.[/quote]Well, if you're driving a couple of miles at a time or having to drive in Brooklyn that may be true. Sorry both of you have do deal with those disadvantages.
