I ask good questions wrote:I just got my AC hooked up using the KA compressor and i am having a problem with the idle. Usually when you turn the AC on the idle bumps up but it just puts a strain on the motor and lowers the idle. I also run an atmospheric BOV which doesnt help things... i stall usually when letting off the gas and pressing the clutch. What controls the idle with the AC hooked up and how do i adjust it? Also my stock electric fan isnt coming on with the AC either.
Another question... do the nismo FPR's come preset at a certain fuel pressure?
Idle will drop with AC cause as you said it puts a strain on the motor. To up the idle adjust the Idle Air Control Valve on the intake manifold. Its down in between the runners. It uses a Phillips Screw Driver to adjust.
Also Nismo FPR does not come preset.
