dattodude »
https://forums.nicoclub.com/dattodude-u30125.html
Thu Mar 30, 2006 3:12 am
float's right on the money.
These things commonly fill up with crap so carby cleaner will help there.
Might also be the base idle is too low, or the base idle bypass is choked up too.
So....with A/C and headlights off, when engine is hot and idling properly as you expect, pull off the AAC Valve connector. The large of the two on the side of the plenum. I believe the idle will drop a couple of hundred revs.
There is a 10mm hex bolthead on the back-side of the AAC and FICD valve unit. This is the base idle mechanical adjuster.
Using the tachometer, and a 10mm spanner, adjust the base idle until it is 800-850rpm.
Once this is done, reconnect the AAC valve connector. The ECU will now have to do less work to manage your idle.
Chris
