PBfrEAk »
https://forums.nicoclub.com/pbfreak-u19783.html
Sun Feb 10, 2008 5:33 am
My car does the same thing.
After I get it running, (still not completely at running temp yet) it seems to run @ 800 rpm or under usually. The whole car seems to vibrates when it drops to 500 or 600. After she warms up it sputters once and a while. Not constantly mind you...just like a miss here and there (I'd say every minute it sputters 5-10 times or so).
I think part of my problem is a bad injector (or two). Once the snow stops here for good, I'm gonna try the test I've seen done before where you pull the plug on each injector one at a time and if the car runs the same then thats the problem.
But I have a feeling it may also be a coil pack problem (or both ).
I'd say if I were you I'd replace the plugs, wires, cap and rotor 1st(if you haven't already. Thats what I did when I 1st bought my car. It ran rough until I changed those and it saw a major improvement with just that done. That is probably the cheapest way to start.
After that if you still have problems I'd work on checking the injectors and coil packs next.
