CaptainHenreh »
https://forums.nicoclub.com/captainhenreh-u7856.html
Thu Aug 26, 2004 4:13 am
Ok, my car idles ~400 rpms lower than normal, my car seems to stumble, and accelerates better at part-throttle than at full throttle. Huge drop in power.
So I check my TPS with a multimeter. The harness side seems fine, with a good ground, and about 5V on B and C pins. I check the TPS, at closed throttle (pin B) i have ~1KOhm, at WOT, I have Just over 8KOhms. Isn't it supposed to max out at ~10? Could this be my problem? I disconnected my TPS and drove the car, there didn't seem to be much of a difference in the action of the car.
What's the consensus? Bad TPS? New TPS is 44 bucks, but I'd rather not spend it without knowing for sure that's the problem.
Thanks in advance for your help.
(and for the people who helped me last time, you guys rock! My coolant temp sensor was disconnected)
