Axel Grungy wrote:theres tons of threads about idle problems, do a search and you will come up with alot. Id check for vacuum leaks, and the connection on your Coolant temp sensor, it might be gummed up.
vacume leaks normaly cause a rise in RPM, I guess he could have a leak, and the IAC tuned to compensate, and that leak fixes its self once and a while but....
burgerwitfry wrote:that's what i thought b/c my intake tube that connects the intake to the throttle body was crack, so i stop driving my car until i get a new one.ill get back on you probably Friday when i replace tomorrow to see if it still low idling. thanks
I wouldn't put to much hope in that, when the car is idling the throttle plate is closed...besides I am not sure what a crack could do besides mess up smooth air flow through the intake while the throttle was open or introduce unmetered air....but neither of those would cause the engine to drop RPMS like that.
So the idle will drop when the car is sitting still, and not bounce right back up?
