You didn’t mention cleaning anything.
Anyways, I was dealing with a P0101 and P0174 on a Cadillac SRX, so I wiped the throttle body with a garage towel on the end of a paintbrush. Too lazy to remove housing and it seemed clean. Sprayed throttle body cleaner on the towel and trying wiping it. Just preventive maintenance but minuscule at that.
My main agenda was the mass air flow sensor, and low and behold I saw what looked like a bug wing inside it. So I blew it out and sprayed mass air flow sensor cleaner inside for a few minutes in controlled bursts.
I did change the engine air filter recently, so maybe a bug wing got shaken loose while I was cleaning that area and found its way into the sensor somehow.
Clear the codes, case closed.
Thank god no need for the dealership.
Moreover, use your favorite fuel cleaners with PEA.
Gas stations give us crappy gas with corn fillers remember and probably from dirty storage tanks. Government don’t care about our gas guzzlers and want everything electric eventually.
