low idle , shaking sputtering engine , sr20det
blacktopforever
Car: 1993 sr20det 240sx
my charge pipe thats connected to my maf sensor blew off yeaterday, when i was driving, the car shut off i popped the hood, and saw that not only did the pipe blow off but the wires to the connecter came out as well, So then i put the wires back in, reconected installed brand new ngk-r bkr7e spark plugs started it up and it appeared to run fine, i drove it up the street not hitting boost, came back, parked it let it sit for about an hour , went to go drive it again and when i start it the idle is low, and sputters, like theres a missfire or somthing any suggestions on what may have caused this , what should the spark plugs be gapped too??
MrSoutherland
Car: S13 - Sr20
I think there gapped to 32 but SEARCH it first. I would use bkr6e, again SEARCHWires to what connector? And make sure your couplers to your pipes are super tight! A lot of people including myself has made that mistake.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
it sounds like you have a vacuum leak...make sure all your couplers are tight
BKR7E gapped to .28-.30
thats what I run...
if you have a vacuum leak, you may have fouled a plug as well perhaps becasue of it running so rich...double check your gap and check for fouling...
