s13satch »
https://forums.nicoclub.com/s13satch-u32571.html
Mon Nov 06, 2006 1:33 pm
A few days ago I decided it was probably time to replace my cap and rotor on my '91 240SX. The car had 119,XXX miles and I had installed an MSD ignition last year around this time. I figured the OE pieces would most likely be shot at this mileage, especially with using the MSD for the last 6K.
It turns out that I was right. My rotor was so burnt that I could not believe the ignition was actually working (see pic). The cap wasn’t as bad, but pretty close.
I bought a new rotor and cap through Nissan and was hoping that the parts would make the car run a lot better. I drove the car around for 2 days and was kind of surprised that I didn’t notice a difference in power, fuel economy, or throttle response. On the 3rd day the car sat. On the 4th day I went for a drive for about 20 minutes. I parked the car at this point and went into a bar to see if any of my friends were there. Not seeing anyone, I went back out to the parking lot and got in my car to leave. When I started the car it was only running on 3 cylinders. This lasted for about a minute. Then, for my entire drive home, the idle was either sporadic, or at a steady 500 rpm, but it did not misfire again.
The next morning I briefly looked around for any obvious issues. The cap was still on tight as were the spark plug wires. So, I started the car and let it warm up. Everything seemed fine so I shut the car off. I did not drive the car until the next morning. It started fine so I left to go run an errand. The car had fully warmed up by the time I had got to the store and there were no signs of the idle/misfire issue from 2 days earlier. However, when I went to start my car to leave, it started on 3 cylinders again. Just as the car had done 2 nights prior, it misfired briefly followed by a sporadic/low idle for the rest of the drive home.
When I got home I decided to do a little more thorough search. Once again I started by checking that the cap and plugs wires were tight. I then proceeded to check the plugs (replaced with the MSD install last year). Next, I checked the connector to my MAF (dirt in it had caused idle issues in the past). Next, I check the ground wires for the motor. Finally, I checked my wiring for the MSD unit to insure that all the connectors were still connected.
My search found that everything appears to be alright. Before I break out the service manual and my multi-meter (or just take it to the shop) I was wondering if anyone has any suggestions for me? Or if anyone had experienced similar problems?
Thanks.
