For it to backfire up the intake the engine is firing when the intake valves are open, check your timing and if you removed timing chain or cams look into the installation of those, hopefully you'll fix yo baby soon!!Flip240sx wrote:I thought i fixed the problem i cleaned my mafs and my throttle body and my car started .but then after 3 weeks it gave me problems again it starts but it idles high and i cant punch the gas pedal because it will choke and back fires from the intake.......do u guys think it that i need to replace my mafs??? anybody that had a similar problem and could help me out i will be very thankful........ .....1991 fastback....Ka24de
