low idle and dies.
pumagod
Car: 95 240sx
95 s14Starts, and runs until engine warms up and then very low idle like lower than 500rpm, and dies. Try to start right after, cranks it won't, but let's say like 5 or 10 minutes later try to start, it does, but it dies.
What do i need to check?
thrasherx89
Car: 90 hatch (91 dohc, tein, z32, ss, injen, energy, b &m)
if you did any work to it recently start with that
then check vaccum lines in the intake and also the brake boster line
a clean and working iacv also start with that
gingerbredman
Car: 93 SE hatch, ~260k miles on the clock, 15" Enkei 92s, still stock. 2009 Sonata bouncing on Eibachs.
The hose going from the intake tube right in front of the throttle body to the right controls idle. If there's a leak there then it will cause idle issues.
