somewhat cheap mods to boost horsepower on the 240sx are, well, first you'll probably want to put a bigger exhaust onit. I would go with either the Apexi GT spec exhaust, which is a 3.74 inch exhaust, the Apexi N1 dual catback exhaust system, or the Invidia N-1 high performance cat-back exhaust. The GT spec, you can get for around $400 on
http://i-m-racing.com/. The Invidia exhaust, you can get on Performancecenter.com for about $600. And the Apexi N1 dual exhaust you can get for around $500 on I-M-Racing.com. Other somewhat inexpensive mods are intakes. You will probably want to get an Injen intake, which you can get for around $200 on I-M-Racing.com, and you can get an Injen cold air intake extension on Performancecenter.com for around $120. You will probably want to get a custom made intake though, and relocate the battery, if you are looking for performance, because the intake tube will be shorter, which will increase throttle response, and your intake wont be running on top of the hot radiator. Also, high performance, spark plugs and spark plug wires can add a few horsepower, and it is a very cheap mod. Of course replacing the header is a good mod. I would recomend the DC Sports 4-2-1 header, even though most people would disagree, Dc Sports has a good name, and their product is street legal, and its not like you dont get as much horsepower with the DC Sports header, 12-14 horsepower gains, and you can get it on
http://Modacar.com, for around $400-$600. Also, fuel injectors, and a new ECU, can get you some good horsepower. Venom, makes good injectors for the 240sx, and Jet is a good ECU. You can probably get up to 35 horsepower out of that combination, but for around $600. Also, another cheap mod for the 240sx, is a new cat converter. Carsound makes a good cat converter, you can get up to 10 ponys out of it, and for only around $100.
http://Performancecenter.com has it. And im pretty sure HKS makes a cat. converter for the s13. I hope these mod suggestions are helpful to you.
Modified by Ni2s4s0aSnX at 11:58 AM 5/10/2005
Modified by Ni2s4s0aSnX at 11:59 AM 5/10/2005
