low/high beams
nghtrain88
Car: 1991 Nissan 300ZXTT
upon switching from normal low beams to high beams, there is a slight pause (about a second or two) where the lights completely go out then the high beams come on. is this possibly a short in the wires? something easily fixed? or requires opening things up and rewiring. The switch from highs to lows works normally.
freakonaleash1187
Car: '93 300ZX N/A, '97 200SX SE
If they turn on, I wouldn't really worry about it. I can't remember if there is a pause in mine, I never turn my high beams on.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Mine switch over instantly, so something isn't right with his.
Zak427
Car: 93 2+2 Twin Turbo
nghtrain88 wrote:upon switching from normal low beams to high beams, there is a slight pause (about a second or two) where the lights completely go out then the high beams come on. is this possibly a short in the wires? something easily fixed? or requires opening things up and rewiring. The switch from highs to lows works normally.
sounds like a delaying relay
nghtrain88
is a delaying relay something that can be fixed easily?
mtcookson
1992 Iinfiniti Q45
and much much more
You could try switching the relays to see if that fixes it. If the relay is bad let me know and I'll just mail you one. I have quite a few laying around.
nghtrain88
switching which relays the highs and lows?
mtcookson
1992 Iinfiniti Q45
and much much more
You can do that or a relay for another system.
nghtrain88
off hand do you know which ones are for the highs/lows? the labels are pretty much worn off on mine
mtcookson
1992 Iinfiniti Q45
and much much more
I can't remember right now, but give me a few minutes and I'll go take a picture of mine.
mtcookson
1992 Iinfiniti Q45
and much much more
Alright, these are a little big but here you go:
http://www.machzracing.com/450...r.jpg
http://www.machzracing.com/450...s.jpg
I would use the fan or fog light relay for the test. What's interesting is it looks like there is only one relay for the low beams and two for the highs so you may want to check the low beam relay as well as it would be very unlikely for two relays to be bad.
nghtrain88
thanks the pics are awesome.. i'll check it and get back to you
nghtrain88
they should be in the same spot even tho your have a 91 and mine is a 93 right?
mtcookson
1992 Iinfiniti Q45
and much much more
I would think they would be... but I'm not 100% sure.
tg
yes they are all identical for all years.
nghtrain88
each of the relays has a plastic cover that i am assuming comes off? any tips to pop those off? also should the battery be disconnected when switching the relays?
mtcookson
1992 Iinfiniti Q45
and much much more
You really shouldn't have to disconnect the battery but you can just to be on the safe side.
The plastic of the relay is all part of the relay. It might have a clip on it to hold it in, I can't remember off hand if those do. If so, you can use a flat head screw driver to hold the clip in then just pull the relay out.
nghtrain88
might sound dumb.. but cant seem to get the relays out.. dunno if you gotta yank em out or if there is more than one tab or what..
nghtrain88
nevermind.. they're out.. still not workin right though.. but i have a friend who is gonna take a look at em tonight
Modified by nghtrain88 at 7:42 PM 5/24/2007
