Low Fuel Indicator???
Stu Segal
Car: G35 Coupe, Silver, Aero / '06 C6 6.0L
Anybody know anything about the Low Fuel indicator?
I have a G35 Coupe, and recently got low on fuel (not quite to "E") and a GREEN indicator light came on, just under the fuel gauge. It took 17.3 gallons (and if this is right, it still had 2.7 gal. left).
As I don't usually associate GREEN indicator lights with warning conditions I'm wondering if there is a different indicator as it gets yet emptier??? Does Nissan/Infiniti use multiple colored lights as a warning system in other models?
Stu
Q451990
Not that I'm aware of... In the Q it's a text message where the dual trip meters are. Every other Nissan product I've owned just has an amber low fuel light.
Heath
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
If you would like, I can check that out for you.
Just mail me a plane ticket, and I'll drive your car around, until it runs out of gas. I better verify the operation a few times.
I may need to keep your car 2 weeks, or so, but I will only charge you for the actual seat time in the car. What can I say? I have a servant heart, and it shows.:icesangel
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Ill supervise Jeff.......
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
Stu, check the owner's manual. All the indicator lights are usually explained, there. If that is no help, try the servcie department, where you got it. There are a few G35 owner here.
Try posting this question on the G35 Coupes & Sedans forum. It is listed under the car specific Forums.
g35driver
Car: Power kite flying
He's an idea. Keep plenty of gas in the tank. I don' t know about you all but I try to make sure that only the freshest premium unleaded gets to my injectors.Never mind I guess i'm being a smart :moon. Kev
Q45tech
As far s I can remember Nissan has always used a 3 gallon minimum to activate the low fuel light...........it won't always be perfect but close.....assuming 50 miles to a station worst case.
Letting your fuel drop below 1/3 of a tank [often] is a sure way to have pump problems later!
