Mine does that! I discovered I had a light when I was odd on a hill, and my gas needle showed under the E line. >.> But I don't run it to the E line ever, so I'd never known I had a light.srellim234 wrote:Sounds like it hasn't changed much. The light in our 2007 comes on with between 2.5 and 3 gallons left, depending on how level the car is sitting.
I like that the car gives you ample warning with well over 50 miles of gas left. I've driven some cars that only alert you with fumes left in the tank.
