clovers525e »
https://forums.nicoclub.com/clovers525e-u47904.html
Thu Feb 01, 2007 5:20 pm
well, i installed my new koyo radiator, used about 50/50 coolant, water mix and went on my way. the factory temp gauge has been about a third of the way up instead of the normal half way. but last night the temp dropped outside and i was driving home from work on the freeway when i noticed the temp gauge sitting right around the bottom of the C on the factory gauge. i'm going to unplug my e fan tonight and see if that helps to bring them back up to proper temp but is there any major problems i face with running such low temps?
