matt0941 wrote:I am a bit confused about the torque peak and redline, revlimiter on the KA-T. If the rev limiter kicks in at 6,200rpm (correction?) when is the torque peak usually reached... a bit after this? And I have heard that you don't really need to shift at the redline due to the fact that the torque peak hits at a bit above 7,000rpm and then the redline is shortly after. Can someone confirm these numbers and also tell me why anyone would want to extend the RPM range if you are past the peak anyways.
While it is theoretically possible to build an engine that could have a torque peak beyond redline, I doubt you'll ever find that this is the case. At least not with a stock motor. It would be rather pointless to build an engine to breath best beyond redline since you'll never see it then. If you modify the motor so that it puts the torque peak beyond redline, then it would be very wise to increase redline, assuming the motor can handle it.
Torque peak on a stock KA occurs at 4400 RPM according to Nissan's rating. The highest redline I've seen on any KA is 6900 RPM. The peak torque is occuring way before that.
There could be a number of reasons to increase redline. If there is still power to be made, then it may extend your powerband some. Keep in mind for a given amount of torque, the higher the RPM it is made in, the better. As an example, lets consider an electric motor. They tend to make the same amount of torque all the way to it's maximum RPM. You'll find that while torque is the same, HP will increase directly with RPM. So the more RPM you have, the more HP you have. internal combustion engines do not have perfectly flat torque curves. Typically it rises to a peak and then starts diminishing. Even though it diminishes, due to the nature of Hp being greater with RPM(for a given amount of torque), the HP rating after the peak torque can still be higher than at peak HP. And in most motors, this is typical.
The reason that HP rises with RPM, is because it's a measure of potential. Frankly, HP is one of the most misleading terms when it comes to rotating engines. Torque is the force that actually accellerates your car. The higher the torque, the faster you will accelerate. So the best acceleration in each gear occurs at peak torque. But some smart guy thought up a device called a transmission. It has many gears that allow the motor to have more leverage. Lower gears allow you to put more torque to the wheels, and therefore you will accelerate faster. Notice your car accelerates its fastest in first gear? So why do we care about HP? Well, since the HP is a number that takes into account torque and acceleration it can tell us more abouot how well it uses the leverage yout transmission provides. Typically, the longer you can stay in a lower gear, the more torque you can get to the wheels at any given time. All motors will get to a point where the speed is mechanically limited, or get to a point where the torque has diminished so much that shifting to the next gear would give you more torque to the ground. Ideally, you would want to shift at the point where the torque measurements at the wheels in each gear crosses the curve for the next gear.
HP is a calculated number. It is much easier to determine how fast a car will be from looking at this number than looking at just the peak torque number. If I were to say a motor had 150 lb-ft of peak torque, it would be hard to determine how fast the car is. It could end up being a motor that spins at 1 RPM but makes 150 lb-ft of torque with a 1 RPM redline. This would not be useful for nothing more than turning something that needed an exact output of 150 lb-ft of torque at 1 RPM. You could have 50 gears, and chances are you'ld never get moving very fast at all. 150 lb-ft of torque at 1 RPM is .028 HP btw.
Now lets consider I tell you that a motor makes 150 HP. It may make 150 HP even at 1 RPM. But at that one RPM, you would have 787,800 lb-ft of torque. Now, even with some seriously tall gears, I'm sure you could accelerate a car with some decency with that much torque.
For the sake of argument, lets assume we have two motors that have a perfectly flat torque curve. Both makes 150 HP. The first one has a redline of 100 RPM and the 2nd can rev to 1000 RPM. The 100 RPM would make 7878 lb-ft of torque. The 1000 RPM motor would make 787.8 lb-ft of torque. If we took the 1000 RPM motor and used a gear ratio of 10:1, you'ld be making 7878 lb-ft of torque(ignoring any drivetrain losses), at 1/10 the speed of the motor. It would actually have the same torque and HP curve as the 100 RPM motor after the gearing. If the gearing were matched so that each motor hit redline at the same wheelspeeds, they would accelerate the same. Even though the 1000 RPM motor made 10 times less torque, it can make the same HP because it can make use of the leverage additional RPM's give. And as you see it is quite linear. 10 times more RPM with 10 times more leverage with 10 times less torque acheived the same results.
Sorry this is so long winded, but I didn't want to leave anything out.
