pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Fri Jun 04, 2004 10:18 am
There could be few things that could cause itone what Nismo mentioned.second you should do a compression and leak down test on your engine, if the compression is bad, the turbo will take a while before it boosts.check for vacuum line on the turbo, I have seen it where if you T-connect the vaccum line of the turbo to something else, it will reduce the vacuum on the turbo thus making it take a while to kick in, make sure that the vaccum line of the turbo isnt shared with any thing else, check your intercooler piping or the intercooler might have a leak
good luck,
PULSAR GTR
