You can read one of the stickies at the top of the forum on how to read the codes on your 93. It's OBD 1 and you have to actually get to the ecu and look at the blinking light to get the code. Check there first and report back.alpar80 wrote:1993 J30, just recently developed a flutter in the low idle range 800RPM and when cruise 1800RPM high gear. Thought is was a misfire, pulled all of the plugs and all are firing fine. Any ideas on what this may be? I was hoping that it could be a sensor or an easy fix? Where would one hook up an OBD? There are no check engine lights.
