G-E »
https://forums.nicoclub.com/g-e-u207983.html
Fri Jan 03, 2014 11:54 pm
It's alright, lots of people are wrong, I remember how z31.com resisted change back when it was even relevant... oddly we're not disagreeing, that was just a cheap backhand for no reason
Evildky is right though, there's a lot of things that may seem like a ton of work, like changing cams, but if you've ever done a timing belt, it's not even that difficult...
Cams are only hard to "find" if you're looking for new items to purchase like JWT units, what people _actually_ do is get their own cams reground by one of the million cam companies like kelford, isky, schnieder, they will already have profiles for various turbo and non-turbo goals, if in doubt, ask them what they recommend -- cost will be around $200-300, labour is less than 2hrs per cam, it can be done with the service manual and common hand tools
Obviously modifications help each other, but consider 200hp an upper limit for non-turbo, 220hp if you get into extensive changes, the cheapest option will always be turbo, as a comparison: 450hp boosted will cost you less than 220hp non-turbo
